Introdução
By following this repair guide, you will be able to replace a broken speaker. The guide will cover how to access the speaker, located within the headset, along with removing the speaker itself. Reassembly will require soldering of the wires back to the speaker.
O que você precisa
Use the broad edge of the plastic spudger and a lot of force to pop off the speaker from the headset.
13 outras pessoas executaram este guia.
2 comentários
Where i can but a replacement headset speaker for Razer Kraken pro neon
