Ir para o conteúdo principal
Razer Huntsman Tournament Edition Keycaps Replacement
O que você precisa
  1. Razer Huntsman Tournament Edition Keycaps Replacement, Keycaps: passo 1, imagem 1 %32
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
    Pergunte ao FixBot
    Comentar
  2. Razer Huntsman Tournament Edition Keycaps Replacement: passo 2, imagem 1 %32 Razer Huntsman Tournament Edition Keycaps Replacement: passo 2, imagem 2 %32
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
    Pergunte ao FixBot
    Comentar
  3. Razer Huntsman Tournament Edition Keycaps Replacement: passo 3, imagem 1 %32 Razer Huntsman Tournament Edition Keycaps Replacement: passo 3, imagem 2 %32 Razer Huntsman Tournament Edition Keycaps Replacement: passo 3, imagem 3 %32
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
    Pergunte ao FixBot
    Comentar
Conclusão
Tony Kuang
Membro desde: 10/25/22
109 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 4-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G3
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 29
Ao todo: 1,835
