Ir para o conteúdo principal
Razer Huntsman Tournament Edition Key Switch Replacement
O que você precisa
  1. Razer Huntsman Tournament Edition Key Switch Replacement, Keycaps: passo 1, imagem 1 %32
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
    Pergunte ao FixBot
    Comentar
  2. Razer Huntsman Tournament Edition Key Switch Replacement: passo 2, imagem 1 %32 Razer Huntsman Tournament Edition Key Switch Replacement: passo 2, imagem 2 %32
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
    Pergunte ao FixBot
    Comentar
  3. Razer Huntsman Tournament Edition Key Switch Replacement: passo 3, imagem 1 %32 Razer Huntsman Tournament Edition Key Switch Replacement: passo 3, imagem 2 %32 Razer Huntsman Tournament Edition Key Switch Replacement: passo 3, imagem 3 %32
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
    Pergunte ao FixBot
    Comentar
  4. Razer Huntsman Tournament Edition Key Switch Replacement, Chassis: passo 4, imagem 1 %32
    • Remove all of the keycaps with a keycap puller.
    Pergunte ao FixBot
    Comentar
  5. Razer Huntsman Tournament Edition Key Switch Replacement: passo 5, imagem 1 %32 Razer Huntsman Tournament Edition Key Switch Replacement: passo 5, imagem 2 %32 Razer Huntsman Tournament Edition Key Switch Replacement: passo 5, imagem 3 %32
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
    • Screw placement and quantity may vary per unit.
    • If you have removed all screws and the front panel cannot be removed, there may be an additional screw near the USB port, below the sticker. (See third photo)
    Pergunte ao FixBot
    Comentar
  6. Razer Huntsman Tournament Edition Key Switch Replacement: passo 6, imagem 1 %32
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
    Pergunte ao FixBot
    Comentar
  7. Razer Huntsman Tournament Edition Key Switch Replacement: passo 7, imagem 1 %32
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
    Pergunte ao FixBot
    Comentar
  8. Razer Huntsman Tournament Edition Key Switch Replacement: passo 8, imagem 1 %32
    • Disconnect the internal cable.
    Pergunte ao FixBot
    Comentar
  9. Razer Huntsman Tournament Edition Key Switch Replacement, Key Switch: passo 9, imagem 1 %32 Razer Huntsman Tournament Edition Key Switch Replacement, Key Switch: passo 9, imagem 2 %32
    • Gently push the key switch off of the mainboard with your thumb.
    Pergunte ao FixBot
    Comentar
Conclusão
Joseph O'Dowd
Membro desde: 10/25/22
419 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 4-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G3
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 64
Ao todo: 2,815
