Ir para o conteúdo principal
Razer DeathAdder Chroma USB Cable Replacement
O que você precisa
  1. Razer DeathAdder Chroma USB Cable Replacement, Outer Casing: passo 1, imagem 1 %32
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Turn the mouse over so the bottom is facing up.
    Pergunte ao FixBot
    Comentar
  2. Razer DeathAdder Chroma USB Cable Replacement: passo 2, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 2, imagem 2 %32
    • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
    Pergunte ao FixBot
    Comentar
  3. Razer DeathAdder Chroma USB Cable Replacement: passo 3, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 3, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
    Pergunte ao FixBot
    Comentar
  4. Razer DeathAdder Chroma USB Cable Replacement: passo 4, imagem 1 %32
    • Use your fingers to identify the location of the screw under the bottom label.
    Pergunte ao FixBot
    Comentar
  5. Razer DeathAdder Chroma USB Cable Replacement: passo 5, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Clear the label away from around the screw for easier removal.
    Pergunte ao FixBot
    Comentar
  6. Razer DeathAdder Chroma USB Cable Replacement: passo 6, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 6, imagem 2 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 6, imagem 3 %32
    • Turn the mouse over so the bottom is facing down.
    • Separate the top casing from the bottom base by pulling the top casing upwards.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
    Pergunte ao FixBot
    Comentar
  7. Razer DeathAdder Chroma USB Cable Replacement: passo 7, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 7, imagem 2 %32
    • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
    • Pulling too hard could damage the wire connections.
    Pergunte ao FixBot
    Comentar
  8. Razer DeathAdder Chroma USB Cable Replacement, Motherboard: passo 8, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement, Motherboard: passo 8, imagem 2 %32
    • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
    Pergunte ao FixBot
    Comentar
  9. Razer DeathAdder Chroma USB Cable Replacement: passo 9, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
    Pergunte ao FixBot
    Comentar
  10. Razer DeathAdder Chroma USB Cable Replacement: passo 10, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 10, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
    Pergunte ao FixBot
    Comentar
  11. Razer DeathAdder Chroma USB Cable Replacement: passo 11, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
    Pergunte ao FixBot
    Comentar
  12. Razer DeathAdder Chroma USB Cable Replacement: passo 12, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 12, imagem 2 %32
    • Disconnect the ribbon connector between the motherboard and the optical sensor.
    Pergunte ao FixBot
    Comentar
  13. Razer DeathAdder Chroma USB Cable Replacement: passo 13, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 13, imagem 2 %32
    • Remove the motherboard by grasping the sides and gently pulling upward.
    Pergunte ao FixBot
    Comentar
  14. Razer DeathAdder Chroma USB Cable Replacement, USB Cable: passo 14, imagem 1 %32
    • Locate the USB cable.
    Pergunte ao FixBot
    Comentar
  15. Razer DeathAdder Chroma USB Cable Replacement: passo 15, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 15, imagem 2 %32
    • Remove the USB cable by pulling it up and out.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Henry Shi
Membro desde: 03/26/17
236 Reputação
Autoria de 1 guia
Equipe
Baylor, Team S5-G2, Williams Spring 2017 Membro de Baylor, Team S5-G2, Williams Spring 2017
BU-WILLIAMS-S17S5G2
3 Membros
Autoria de 6 guias
5Comentários do guia
Thank you! It realy worked. Btw: The cable for the Deathadder 2013 is working for the Chroma and Elite as well. I Just tried it :)
Pokefreeks - Responder Compartilhar
Thanks for the advice
João Costa Santos - Responder Compartilhar
Great and easy guide thanx alot, saved me a new mouse :)
jesperkb - Responder Compartilhar
Is there a reliable website where I can get a replacement cable with low delivery time?
Bubbles EXE - Responder Compartilhar
where can i get the cable from?
Mourya Singham - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 48
Ao todo: 15,480
