Ir para o conteúdo principal
Razer Blade Pro 17 2019 Battery Replacement
O que você precisa
  1. Razer Blade Pro 17 2019 Battery Replacement, Battery: passo 1, imagem 1 %32 Razer Blade Pro 17 2019 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Unplug the laptop.
    • Press and hold the power button to shut down the laptop.
  2. Razer Blade Pro 17 2019 Battery Replacement: passo 2, imagem 1 %32 Razer Blade Pro 17 2019 Battery Replacement: passo 2, imagem 2 %32 Razer Blade Pro 17 2019 Battery Replacement: passo 2, imagem 3 %32
    • Remove the 12 screws that secure the lower case with a T5 Torx screwdriver.
  3. Razer Blade Pro 17 2019 Battery Replacement: passo 3, imagem 1 %32 Razer Blade Pro 17 2019 Battery Replacement: passo 3, imagem 2 %32 Razer Blade Pro 17 2019 Battery Replacement: passo 3, imagem 3 %32
    • Insert the opening picks into the gap between the back plate and the body of the laptop and pry around the perimeter until the lower case releases.
    • It is easier to use the gap at the ethernet port.
    • Lift up and remove the lower case.
    • Be careful not to place anything on the back to avoid scratching any components.
  4. Razer Blade Pro 17 2019 Battery Replacement: passo 4, imagem 1 %32 Razer Blade Pro 17 2019 Battery Replacement: passo 4, imagem 2 %32 Razer Blade Pro 17 2019 Battery Replacement: passo 4, imagem 3 %32
    • Remove the black sticker on the fan assembly.
  5. Razer Blade Pro 17 2019 Battery Replacement: passo 5, imagem 1 %32 Razer Blade Pro 17 2019 Battery Replacement: passo 5, imagem 2 %32
    • Use your fingernails to gently "walk" the battery connector directly out of its port.
    • Do not pull directly on the wires, as depicted in the photo.
  6. Razer Blade Pro 17 2019 Battery Replacement: passo 6, imagem 1 %32 Razer Blade Pro 17 2019 Battery Replacement: passo 6, imagem 2 %32
    • Use your fingernails or a spudger to gently lever the fan connector directly out of its socket.
    • Do not pull directly on the wires, as show in the photos.
  7. Razer Blade Pro 17 2019 Battery Replacement: passo 7, imagem 1 %32 Razer Blade Pro 17 2019 Battery Replacement: passo 7, imagem 2 %32 Razer Blade Pro 17 2019 Battery Replacement: passo 7, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the 10 screws that secure the battery and fan assembly.
  8. Razer Blade Pro 17 2019 Battery Replacement: passo 8, imagem 1 %32 Razer Blade Pro 17 2019 Battery Replacement: passo 8, imagem 2 %32 Razer Blade Pro 17 2019 Battery Replacement: passo 8, imagem 3 %32
    • Lift the fan assembly and battery out of the chassis.
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
Nate
Membro desde: 04/15/24
157 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-3, Morris Spring 2024 Membro de UC Davis, Team 2-3, Morris Spring 2024
UCD-MORRIS-S24S2G3
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 25
Duração total: 46
