Introdução
Use this guide to remove or replace the left fan in your Razer Blade 15" (2020) laptop.
Note: This guide refers to the "left" fan as the one on your left-hand side when the screen is open and facing you.
O que você precisa
Unplug all cables and fully shut down your laptop.
Close the lid and flip your laptop over so the back cover faces up.
Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
Apply a heated iOpener to the battery cable tape for one minute.
Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
The antenna cables look very similar. Label one of them with a piece of tape or marker and remember which socket it connects to.
Ferramenta utilizada nesse passo:Tweezers$4.99
Insert one arm of angled tweezers under the metal neck of each antenna cable and pry up to disconnect it.
Grab the pull tab on the screen connector.
Pull up to disconnect the connector from its socket.
Use the point of your spudger to press on alternating sides of the charging port connector to "walk" it out of its socket.
Unclip the screen and antenna cables from the fan and move them over the right edge of the laptop.
Use a Phillips screwdriver to remove the two 6.7 mm screws securing the left fan.
