Introdução
This repair guide will show you how to replace the battery from your Razer Barracuda X headphones.
If the battery is swollen, take precautions.
Attempt to dispose of the battery responsibly (It may be the law in your area).
For best results, after installing a new battery, calibrate it.
O que você precisa
Remove the cushion by pulling it off from the edge and out from the grooves.
Continue to pull the cushion away from the speaker until the cushion is fully separated.
3 outras pessoas executaram este guia.
7 comentários
What is the voltage of the battery?
It’s a 3.7V battery.
Battery info Barracuda X Wireless (2022) version but I believe the non 2022 version also:
55345PN2 / 1ICP6/35/51 1200mAh/4.44Wh
Dominick -
Si, 3,7 v se ve muy mal en la foto del Paso 4
How small is that battery?? i took mine apart and i saw i got the wrong size battery in general.
