Ir para o conteúdo principal
Razer Barracuda X Battery Replacement
O que você precisa
  1. Razer Barracuda X Battery Replacement, Battery: passo 1, imagem 1 %32 Razer Barracuda X Battery Replacement, Battery: passo 1, imagem 2 %32 Razer Barracuda X Battery Replacement, Battery: passo 1, imagem 3 %32
    • Remove the cushion by pulling it off from the edge and out from the grooves.
    • Continue to pull the cushion away from the speaker until the cushion is fully separated.
  2. Razer Barracuda X Battery Replacement: passo 2, imagem 1 %32
    • Remove the four 6 mm Phillips #1 screws from the left side of the speaker casing.
  3. Razer Barracuda X Battery Replacement: passo 3, imagem 1 %32 Razer Barracuda X Battery Replacement: passo 3, imagem 2 %32
    • Gently pull the speaker casing away from the shell.
    • Place it face down to access the battery.
  4. Razer Barracuda X Battery Replacement: passo 4, imagem 1 %32 Razer Barracuda X Battery Replacement: passo 4, imagem 2 %32
    • Unplug the battery from the socket.
    • Use a spudger to gently lift the battery up.
    • Remove the battery.
Conclusão
3 outras pessoas executaram este guia.
Micah Ortiz
Membro desde: 10/26/22
247 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-3, Petersen Fall 2022 Membro de UMass Dartmouth, Team 2-3, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G3
Membros da 4
Autoria de 7 guias
7 comentários
What is the voltage of the battery?
Bavo Van Rillaer - Responder
It’s a 3.7V battery.
Dániel Baranyi -
Battery info Barracuda X Wireless (2022) version but I believe the non 2022 version also:
55345PN2 / 1ICP6/35/51 1200mAh/4.44Wh
Dominick -
Si, 3,7 v se ve muy mal en la foto del Paso 4
Carlos López (España - Spain) - Responder
How small is that battery?? i took mine apart and i saw i got the wrong size battery in general.
JPStruggle - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 62
Últimos 30 dias: 243
Duração total: 3,493
