Ir para o conteúdo principal
Raspberry Pi 3 SD Card Replacement
O que você precisa
  1. Raspberry Pi 3 SD Card Replacement, Raspberry Pi 3 SD Card replacement.: passo 1, imagem 1 %32
    • The Raspberry Pi 3 should look like this closed.
    Pergunte ao FixBot
    Comentar
  2. Raspberry Pi 3 SD Card Replacement, Top cover removal: passo 2, imagem 1 %32
    • Open the top lid like I have done on the image.
    • The top is marked that you are gonna remove in the next step.
    Pergunte ao FixBot
    Comentar
  3. Raspberry Pi 3 SD Card Replacement, Cover for GPIO Hider and IO Shield removal: passo 3, imagem 1 %32
    • Now remove the cover for the two covers.
    • It should look like the image.
    • I have marked the covers for the next step.
    Pergunte ao FixBot
    Comentar
  4. Raspberry Pi 3 SD Card Replacement, IO Shield and GPIO Hider removal: passo 4, imagem 1 %32
    • Remove the two sides.
    Pergunte ao FixBot
    Comentar
  5. Raspberry Pi 3 SD Card Replacement, Removal.: passo 5, imagem 1 %32 Raspberry Pi 3 SD Card Replacement, Removal.: passo 5, imagem 2 %32
    • Now we should successfully have removed the case.
    • Notice that the side shown on the first image is the one that we are intrested in.
    • When we have flipped the Pi 3 over we can remove the SD card.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
ΛΛKΛRΞT
Membro desde: 11/22/17
229 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 34
Ao todo: 2,724
