Ir para o conteúdo principal
RYDIS H68 Pro Wheel Replacement
O que você precisa
    1. RYDIS H68 Pro Wheel  Replacement, Battery: passo 1, imagem 1 %32 RYDIS H68 Pro Wheel  Replacement, Battery: passo 1, imagem 2 %32
      • Flip the vacuum over so that the wheels are facing you.
      • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
      Pergunte ao FixBot
      Comentar
    2. RYDIS H68 Pro Wheel  Replacement: passo 2, imagem 1 %32
      • Lift the battery cover up to reveal the battery.
      • Remove the battery.
      Pergunte ao FixBot
      Comentar
    1. RYDIS H68 Pro Wheel  Replacement, Bumper: passo 3, imagem 1 %32 RYDIS H68 Pro Wheel  Replacement, Bumper: passo 3, imagem 2 %32 RYDIS H68 Pro Wheel  Replacement, Bumper: passo 3, imagem 3 %32
      • Remove the eight 10 mm Phillips #1 screws.
      Pergunte ao FixBot
      Comentar
    2. RYDIS H68 Pro Wheel  Replacement: passo 4, imagem 1 %32 RYDIS H68 Pro Wheel  Replacement: passo 4, imagem 2 %32 RYDIS H68 Pro Wheel  Replacement: passo 4, imagem 3 %32
      • Hold the front bumper and pull it off.
      • It requires a lot of force to pull the bumper off.
      Pergunte ao FixBot
      Comentar
    3. RYDIS H68 Pro Wheel  Replacement: passo 5, imagem 1 %32 RYDIS H68 Pro Wheel  Replacement: passo 5, imagem 2 %32 RYDIS H68 Pro Wheel  Replacement: passo 5, imagem 3 %32
      • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
      Pergunte ao FixBot
      Comentar
    1. RYDIS H68 Pro Wheel  Replacement, Wheel assembly: passo 6, imagem 1 %32
      • Remove three 10mm Philips #1 screws that are securing the wheel assembly.
      Pergunte ao FixBot
      Comentar
    2. RYDIS H68 Pro Wheel  Replacement: passo 7, imagem 1 %32 RYDIS H68 Pro Wheel  Replacement: passo 7, imagem 2 %32
      • Remove the 10mm Phillips #1 screw securing the spring.
      • Then undo the spring from the plastic hook to completely remove it from the wheel assembly.
      Pergunte ao FixBot
      Comentar
    3. RYDIS H68 Pro Wheel  Replacement: passo 8, imagem 1 %32 RYDIS H68 Pro Wheel  Replacement: passo 8, imagem 2 %32 RYDIS H68 Pro Wheel  Replacement: passo 8, imagem 3 %32
      • Lift up on the plastic piece to remove the entire wheel assembly.
      Pergunte ao FixBot
      Comentar
    4. RYDIS H68 Pro Wheel  Replacement: passo 9, imagem 1 %32 RYDIS H68 Pro Wheel  Replacement: passo 9, imagem 2 %32 RYDIS H68 Pro Wheel  Replacement: passo 9, imagem 3 %32
      • Remove the plastic frame by pulling outward on the two spots where it is fastened.
      Pergunte ao FixBot
      Comentar
    5. RYDIS H68 Pro Wheel  Replacement: passo 10, imagem 1 %32 RYDIS H68 Pro Wheel  Replacement: passo 10, imagem 2 %32
      • Remove the four 10mm Phillips #1 screws around the edges of the cover.
      Pergunte ao FixBot
      Comentar
    6. RYDIS H68 Pro Wheel  Replacement: passo 11, imagem 1 %32 RYDIS H68 Pro Wheel  Replacement: passo 11, imagem 2 %32 RYDIS H68 Pro Wheel  Replacement: passo 11, imagem 3 %32
      • Lift up on the top cover to remove it.
      • Removing the top cover reveals the gear system consisting of three gears.
      Pergunte ao FixBot
      Comentar
Conclusão
Shawn O'Meara
Membro desde: 02/27/17
101 Reputação
Autoria de 1 guia
Equipe
USFT-Lacy-S17S005G2 Membro de USFT-Lacy-S17S005G2
Local Repair Groups
4 Membros
Autoria de 30 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 703
