Ir para o conteúdo principal
ROG Strix G15 G512LI M.2 SSD Replacement
O que você precisa
  1. ROG Strix G15 G512LI M.2 SSD Replacement, Removing The Cover: passo 1, imagem 1 %32
    • Remove the screws from the compartment cover, As show in the diagram, unscrew the screws labeled "A" first. before unscrewing "B", Don't remove screw "B" from the cover.
  2. ROG Strix G15 G512LI M.2 SSD Replacement: passo 2, imagem 1 %32
    • Remove the panel, but be careful as there are 2 cables linking the RGB light bar to the motherboard, carefully and gently detach them from the motherboard and lift the panel.
  3. ROG Strix G15 G512LI M.2 SSD Replacement, Installing The SSD: passo 3, imagem 1 %32 ROG Strix G15 G512LI M.2 SSD Replacement, Installing The SSD: passo 3, imagem 2 %32
    • Locate the M.2 SSD slots, the First and Third slots both support SATA and PCIe NVMe M.2 SSDs, and the second M.2 Slot only supports PCIe NVMe SSDs
    • Next, Insert the NVMe SSD, and screw the SSD into place with the retaining screws
Conclusão
Uma outra pessoa concluiu este guia.
June
Membro desde: 09/28/21
590 Reputação
Autoria de 3 guias
2 comentários
how to fix the light bar i have one side wont light on
fethallah - Responder
are the m.2 nvme slot PCIe 3.0x4 and are they all the same speed or type?
Yousef Suwaidan - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 32
Últimos 30 dias: 200
Ao todo: 7,830
