Ir para o conteúdo principal
RIDGID R84015 X2 Speed Switch Replacement
O que você precisa
  1. RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: passo 1, imagem 1 %32 RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: passo 1, imagem 2 %32
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Speed Switch Replacement: passo 2, imagem 1 %32
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Speed Switch Replacement: passo 3, imagem 1 %32 RIDGID R84015 X2 Speed Switch Replacement: passo 3, imagem 2 %32
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Speed Switch Replacement, Speed Switch: passo 4, imagem 1 %32
    • Locate small metal bar above plastic part of drill.
    • Attempt to move bar back and forth. If it wont move, try to move it while rotating the chuck. If it still will not move, there is a problem with the gears. For help see the Planetary Gear Replacement Guide
  5. RIDGID R84015 X2 Speed Switch Replacement: passo 5, imagem 1 %32 RIDGID R84015 X2 Speed Switch Replacement: passo 5, imagem 2 %32
    • If the bar moves, next check the small plastic switch that is numbered 1 and 2.
    • Make sure the small tabs on the underside of the switch that move the bar are intact.
    • Replace switch as needed.
Conclusão
Evan Long
Membro desde: 04/15/10
262 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 15-48, Garner Spring 2010 Membro de Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
Membros da 6
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 3,639
