Introdução
Follow these steps to disassemble the drill and replace the planetary gear for the RIDGID R84015 X2 power drill.
O que você precisa
Remove the backplate.
Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
Prepare to remove the gear chamber.
Using the Phillips #2 screwdriver, unscrew the four screws at the rear of the plastic gear chamber.
4 outras pessoas executaram este guia.
