Ir para o conteúdo principal
REL T5 Repaste transistors
    1. REL T5 Repaste transistors, Repaste heatsink and pads: passo 1, imagem 1 %32 REL T5 Repaste transistors, Repaste heatsink and pads: passo 1, imagem 2 %32 REL T5 Repaste transistors, Repaste heatsink and pads: passo 1, imagem 3 %32
      • Re-apply thermal grease. Make sure to use an appropriate type. Hint: CPU paste is usually not the best solution.
      • Apply a little dot on the pad and place on the heatsink.
      • After speading it with a spatula, stick two together, and slide to distribute evenly.
      • Careful as to not damage the pads!
      Pergunte ao FixBot
      Comentar
    2. REL T5 Repaste transistors: passo 2, imagem 1 %32
      • Apply a thin layer using the spatula on the transistors as well.
      • Mount the amplifier board back on its place.
      • Carefully set the transistors using the screws.
      • Fix the power board using its screws.
      • Check that there are no shorts between the transistors and the heatsink or backplate.
      • TODO image of mounted board
      Pergunte ao FixBot
      Comentar
Conclusão
Jasper van Zuijlen
Membro desde: 04/21/25
1.044 Reputação
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 11
Ao todo: 11
