Ir para o conteúdo principal
RCA RCT6272W23 Speaker Replacement
O que você precisa
  1. RCA RCT6272W23 Speaker Replacement, Case: passo 1, imagem 1 %32 RCA RCT6272W23 Speaker Replacement, Case: passo 1, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Speaker Replacement: passo 2, imagem 1 %32 RCA RCT6272W23 Speaker Replacement: passo 2, imagem 2 %32
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Speaker Replacement, Speaker: passo 3, imagem 1 %32
    • Remove the soldered wire connections to the speaker.
    • Soldering irons can cause burns and severely damage your device. If in doubt, pause and think about it.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Speaker Replacement: passo 4, imagem 1 %32
    • Pry the speaker gently out of its plastic enclosure using a spudger.
Conclusão
Stephen Radachy
Membro desde: 03/17/15
819 Reputação
Autoria de 5 guias
Equipe
Michigan Tech, Team 1-5, Lauer Spring 2015 Membro de Michigan Tech, Team 1-5, Lauer Spring 2015
MTU-LAUER-S15S1G5
Membros da 2
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 374
