Ir para o conteúdo principal
RCA RCT6272W23 Rear Camera Replacement
O que você precisa
  1. RCA RCT6272W23 Rear Camera Replacement, Case: passo 1, imagem 1 %32 RCA RCT6272W23 Rear Camera Replacement, Case: passo 1, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Rear Camera Replacement: passo 2, imagem 1 %32 RCA RCT6272W23 Rear Camera Replacement: passo 2, imagem 2 %32
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Rear Camera Replacement, Motherboard: passo 3, imagem 1 %32 RCA RCT6272W23 Rear Camera Replacement, Motherboard: passo 3, imagem 2 %32 RCA RCT6272W23 Rear Camera Replacement, Motherboard: passo 3, imagem 3 %32
    • Use a soldering iron to remove the soldered connections on the motherboard
    • For your safety and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Rear Camera Replacement: passo 4, imagem 1 %32
    • Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
  5. RCA RCT6272W23 Rear Camera Replacement: passo 5, imagem 1 %32 RCA RCT6272W23 Rear Camera Replacement: passo 5, imagem 2 %32
    • Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
  6. RCA RCT6272W23 Rear Camera Replacement: passo 6, imagem 1 %32
    • Pull up the motherboard from the rest of the body.
  7. RCA RCT6272W23 Rear Camera Replacement, Rear Camera: passo 7, imagem 1 %32
    • Using a spudger, gently pry off the camera from the back of the display
Conclusão
Stephen Radachy
Membro desde: 03/17/15
819 Reputação
Autoria de 5 guias
Equipe
Michigan Tech, Team 1-5, Lauer Spring 2015 Membro de Michigan Tech, Team 1-5, Lauer Spring 2015
MTU-LAUER-S15S1G5
2 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Ao todo: 374
