Ir para o conteúdo principal
RCA CC310 Onboard Microphone Replacement
O que você precisa
    1. RCA CC310 Onboard Microphone Replacement, Onboard Microphone: passo 1, imagem 1 %32 RCA CC310 Onboard Microphone Replacement, Onboard Microphone: passo 1, imagem 2 %32
      • Lift the metal flap and slide the viewfinder off to the right.
      Pergunte ao FixBot
      Comentar
    2. RCA CC310 Onboard Microphone Replacement: passo 2, imagem 1 %32 RCA CC310 Onboard Microphone Replacement: passo 2, imagem 2 %32 RCA CC310 Onboard Microphone Replacement: passo 2, imagem 3 %32
      • Unscrew the 7.0mm ph#0 screw on the underside where the cable connects.
      • Lift the plastic where the cable is connected to the viewfinder.
      • Disconnect the cable inside by pulling it apart.
      Pergunte ao FixBot
      Comentar
    3. RCA CC310 Onboard Microphone Replacement: passo 3, imagem 1 %32 RCA CC310 Onboard Microphone Replacement: passo 3, imagem 2 %32
      • Unscrew the two 7mm ph#0 screws on the underside of the viewfinder assembly.
      • Lift the viewfinder plastic assembly up.
      Pergunte ao FixBot
      Comentar
    4. RCA CC310 Onboard Microphone Replacement: passo 4, imagem 1 %32 RCA CC310 Onboard Microphone Replacement: passo 4, imagem 2 %32
      • Lift the microphone circuit board straight up.
      • Unclip the cable connected to the circuit board.
      Pergunte ao FixBot
      Comentar
    5. RCA CC310 Onboard Microphone Replacement: passo 5, imagem 1 %32
      • Turn the microphone circuit board over.
      • Unscrew the two Ph#0 screws holding the plastic housing on the circuit board.
      Pergunte ao FixBot
      Comentar
    6. RCA CC310 Onboard Microphone Replacement: passo 6, imagem 1 %32
      • Desolder the metal protective housing using a soldering iron.
      • Desolder the microphone and replace it.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Oliver Adams
Membro desde: 01/19/11
629 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 5-20, Amido Winter 2011 Membro de Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 27
Ao todo: 1,300
