Ir para o conteúdo principal
RCA 8 Apollo Screen Replacement
O que você precisa
    1. RCA 8 Apollo Screen Replacement, Back Panel: passo 1, imagem 1 %32
      • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your tablet before beginning to disassemble.
      Pergunte ao FixBot
      Comentar
    2. RCA 8 Apollo Screen Replacement: passo 2, imagem 1 %32 RCA 8 Apollo Screen Replacement: passo 2, imagem 2 %32
      • Insert an iFixit opening tool into the gap between the tablet and back panel.
      • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
      • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
      Pergunte ao FixBot
      Comentar
    3. RCA 8 Apollo Screen Replacement: passo 3, imagem 1 %32 RCA 8 Apollo Screen Replacement: passo 3, imagem 2 %32
      • Disconnect the red and black speaker wires from the tablet.
      • The front and back of the tablet will be disconnected.
      Pergunte ao FixBot
      Comentar
    1. RCA 8 Apollo Screen Replacement, Display Assembly: passo 4, imagem 1 %32 RCA 8 Apollo Screen Replacement, Display Assembly: passo 4, imagem 2 %32 RCA 8 Apollo Screen Replacement, Display Assembly: passo 4, imagem 3 %32
      • Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
      • Remove the yellow tape that is around the battery.
      • Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
      • If the connector is misaligned, the pins can bend, causing permanent damage.
      Pergunte ao FixBot
      Comentar
    2. RCA 8 Apollo Screen Replacement: passo 5, imagem 1 %32
      • Remove the three screws from the motherboard using a Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    3. RCA 8 Apollo Screen Replacement: passo 6, imagem 1 %32
      • Remove the battery and motherboard together from the tablet.
      • If the tablet needs a battery replacement, disconnect the battery and replace it with a new one.
      • The battery might be glued down; you will just need to slowly remove the battery as the adhesive releases.
      Pergunte ao FixBot
      Comentar
    1. RCA 8 Apollo Screen Replacement, Screen: passo 7, imagem 1 %32 RCA 8 Apollo Screen Replacement, Screen: passo 7, imagem 2 %32 RCA 8 Apollo Screen Replacement, Screen: passo 7, imagem 3 %32
      • Remove the screw from the bottom left of the tablet.
      • Place an opening tool under the screen.
      • Pry up the screen and it will unclip from the clips holding the screen down.
      • Avoid using too much force to prevent the glass from breaking.
      Pergunte ao FixBot
      Comentar
Conclusão
McKenna Shipper
Membro desde: 04/12/24
123 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 263
