Ir para o conteúdo principal
RCA 8 Apollo Back Panel Replacement
O que você precisa
    1. RCA 8 Apollo Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
      • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your tablet before beginning to disassemble.
      Pergunte ao FixBot
      Comentar
    2. RCA 8 Apollo Back Panel Replacement: passo 2, imagem 1 %32 RCA 8 Apollo Back Panel Replacement: passo 2, imagem 2 %32
      • Insert an iFixit opening tool into the gap between the tablet and back panel.
      • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
      • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
      Pergunte ao FixBot
      Comentar
    3. RCA 8 Apollo Back Panel Replacement: passo 3, imagem 1 %32 RCA 8 Apollo Back Panel Replacement: passo 3, imagem 2 %32
      • Disconnect the red and black speaker wires from the tablet.
      • The front and back of the tablet will be disconnected.
      Pergunte ao FixBot
      Comentar
Conclusão
Chantel Pfiefer
Membro desde: 04/15/24
219 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 194
