Ir para o conteúdo principal
R52WH74 Motherboard Component Replacement
O que você precisa
  1. R52WH74 Motherboard Component Replacement, Convergence: passo 1, imagem 1 %32 R52WH74 Motherboard Component Replacement, Convergence: passo 1, imagem 2 %32 R52WH74 Motherboard Component Replacement, Convergence: passo 1, imagem 3 %32
    • Here is what it looks like when the convergence is off.
    • Remove the seven screws from the back.
    • Remove the two screws from the left side.
    Pergunte ao FixBot
    Comentar
  2. R52WH74 Motherboard Component Replacement: passo 2, imagem 1 %32 R52WH74 Motherboard Component Replacement: passo 2, imagem 2 %32 R52WH74 Motherboard Component Replacement: passo 2, imagem 3 %32
    • Remove the two screws on the right side.
    • Also visible is the screw by the power cable.
    • Remove the back of the TV
    • All the screws on this TV are the same length, and all are T20.
    Pergunte ao FixBot
    Comentar
  3. R52WH74 Motherboard Component Replacement: passo 3, imagem 1 %32 R52WH74 Motherboard Component Replacement: passo 3, imagem 2 %32 R52WH74 Motherboard Component Replacement: passo 3, imagem 3 %32
    • This is the deflection power board part number PSB-260
    • Closer look on the the same boards revels all the connectors (definitely not nice)
    • Mark all the cables with a piece of masking tape and there relevant position on the board. This will make assembly easier.
    Pergunte ao FixBot
    Comentar
  4. R52WH74 Motherboard Component Replacement: passo 4, imagem 1 %32 R52WH74 Motherboard Component Replacement: passo 4, imagem 2 %32 R52WH74 Motherboard Component Replacement: passo 4, imagem 3 %32
    • Drawing of the connectors on the Power Board
    • Remove all the cables from the power board. Each cable does have its own distinct connector and will not fit into another connector. This will make it easier to re-assemble the chassis.
    • DO NOT REMOVE THE RED WIRES FROM THE FLYBACK TRANSFORMER. Keep those attached.
    • To remove the flat ribbon cables from the BL111 and the BP005 connectors, just pull straight up on the cables. Hold the cable close to the connector end and pull straight up. They are compression connectors and have no clips.
    • The power board is held to the plastic chassis by 8 plastic tabs on the perimeter. Push those away from the board and toward the plastic side.
    Pergunte ao FixBot
    Comentar
  5. R52WH74 Motherboard Component Replacement: passo 5, imagem 1 %32 R52WH74 Motherboard Component Replacement: passo 5, imagem 2 %32 R52WH74 Motherboard Component Replacement: passo 5, imagem 3 %32
    • There are two plastic tab on the inside of the board. One on the bottom.
    • The other one on the top side.
    • Start at the front side of the plastic chassis and squeeze the tab away from the board, at the same time, lift the board in an angled motion out of the chassis.
    Pergunte ao FixBot
    Comentar
  6. R52WH74 Motherboard Component Replacement: passo 6, imagem 1 %32 R52WH74 Motherboard Component Replacement: passo 6, imagem 2 %32 R52WH74 Motherboard Component Replacement: passo 6, imagem 3 %32
    • Continue to lift until the last of tabs has been cleared.
    • With all the tabs cleared move the board out of the plastic chassis and slightly to the left. There should be enough room with the Fly Back Transformer cables still attached.
    • With the board cleared of the chassis, this is the area that contains all the components that are to be replaced.
    Pergunte ao FixBot
    Comentar
  7. R52WH74 Motherboard Component Replacement: passo 7, imagem 1 %32 R52WH74 Motherboard Component Replacement: passo 7, imagem 2 %32 R52WH74 Motherboard Component Replacement: passo 7, imagem 3 %32
    • Here are the three components:
    • FL231 125V UL FA LL .400A TE5 fuse
    • DL231 Diode Rectifier 1A 600V
    • CL230 Capacitor 100uF 100V
    • Unsolder all three components. Use solder wick and some flux,or a solder sucker.
    • View of the solder side with components removed.
    Pergunte ao FixBot
    Comentar
  8. R52WH74 Motherboard Component Replacement: passo 8, imagem 1 %32 R52WH74 Motherboard Component Replacement: passo 8, imagem 2 %32 R52WH74 Motherboard Component Replacement: passo 8, imagem 3 %32
    • Replace the components by guiding the legs through the holes in the board. Bend the legs to the side to keep the component in place. Solder in the usual way.
    • After the component is properly solder to the board, cut the excessive length of the contacts with a pair of side cutters.
    • The only other thing I recommend is to either reflow, or resolder the flyback transformer contacts. The ones on this board looked like they may have gotten hot.
    Pergunte ao FixBot
    Comentar
  9. R52WH74 Motherboard Component Replacement: passo 9, imagem 1 %32 R52WH74 Motherboard Component Replacement: passo 9, imagem 2 %32
    • With the components replaced it is time to reassemble the TV. Here is another look at the plastic chassis with all the clips.
    • Hopefully your results will be like mine. Perfect convergence. Totals cost for the repair $1 for parts and $5 for shipping. Total time about 2 hours.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
oldturkey03
Membro desde: 09/29/10
857.920 Reputação
Autoria de 123 guias
6Comentários do guia
do you know anything about xbox 360 drives
kevin - Responder Compartilhar
I used your guide to locate and repair the convergence fuse with succuss! It's crazy to think that I was near trashing this tv over a $2 repair! Thanks for the advice!!
jason - Responder Compartilhar
I changed some Capacitors on my TV after it was done my convergence were out of wack. When I tried lining up the colors from TV settings it only corrects my right side. Before I changed my Capacitors the picture on my TV was excellent. What should I do?
Sherie Freeman - Responder Compartilhar
i replaced all 3 parts and for some reason i still have convergence issues. help please!
alumianeilcarrillo - Responder Compartilhar
I want to replace the entire deflector board (FSB 260), flyback and all included. I need to remove the red wire where it plugs into the CRT tube ( I assume that's where it ends). Do you know if I can easily access that spot where it connects under the tube to remove it?
Doctor Spaceman - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 57
Ao todo: 15,518
