Ir para o conteúdo principal
Puritan Bennett 840 Oxygen Sensor Replacement
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
    1. Puritan Bennett 840 Oxygen Sensor Replacement, Oxygen Sensor: passo 1, imagem 1 %32
      • Locate the flexible oxygen sensor access cover on the top edge of the cabinet and firmly push the center of the lower flap of the access cover until the lower flap is dislodged from the cabinet.
      Pergunte ao FixBot
      Comentar
    2. Puritan Bennett 840 Oxygen Sensor Replacement: passo 2, imagem 1 %32
      • Pinch the bottom and top flaps of the access cover firmly together and pull the access cover away from the cabinet to remove.
      Pergunte ao FixBot
      Comentar
    3. Puritan Bennett 840 Oxygen Sensor Replacement: passo 3, imagem 1 %32
      • Press the small white release tab away from the sensor cable connector to release the sensor cable connector.
      • While continually pressing the release tab, gently pull the connector from the oxygen sensor.
      Pergunte ao FixBot
      Comentar
    4. Puritan Bennett 840 Oxygen Sensor Replacement: passo 4, imagem 1 %32
      • Unscrew (counter-clockwise) and remove the oxygen sensor.
      Pergunte ao FixBot
      Comentar
    5. Puritan Bennett 840 Oxygen Sensor Replacement: passo 5, imagem 1 %32
      • Open the replacement oxygen sensor and O-ring. Make sure the O-ring is at the threaded base of the oxygen sensor, and screw (clockwise) until snug.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Calibrate new oxygen sensor by pressing 100% O2/ CAL 2 min key. Run an SST to check the system before using the ventilator on a patient.
Gabrielle Reyes
Membro desde: 04/09/20
154 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S7-G4, Paton Spring 2020 Membro de Cal Poly, Team S7-G4, Paton Spring 2020
CPSU-PATON-S20S7G4
3 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 40
Ao todo: 2,582
