Ir para o conteúdo principal
Protocol Videodrone AP Camera Replacement
O que você precisa
  1. Protocol Videodrone AP Camera Replacement, Camera: passo 1, imagem 1 %32
    • Power off the drone before proceeding with this repair.
  2. Protocol Videodrone AP Camera Replacement: passo 2, imagem 1 %32
    • Remove the propeller screws (1 per propeller).
    • You can use the Phillips #0 screwdriver if you don't own the one included with drone.
  3. Protocol Videodrone AP Camera Replacement: passo 3, imagem 1 %32 Protocol Videodrone AP Camera Replacement: passo 3, imagem 2 %32
    • Remove the screws holding on the propeller guards using the Phillips #0 screwdriver (2 per propeller guard).
  4. Protocol Videodrone AP Camera Replacement: passo 4, imagem 1 %32 Protocol Videodrone AP Camera Replacement: passo 4, imagem 2 %32
    • Using the Phillips #0 screwdriver to remove the eight screws securing the body of the drone.
  5. Protocol Videodrone AP Camera Replacement: passo 5, imagem 1 %32
    • Remove the case.
  6. Protocol Videodrone AP Camera Replacement: passo 6, imagem 1 %32
    • Remove the propeller motor screws (3 per motor).
    • The plastic screw housing is attached to the motor.
  7. Protocol Videodrone AP Camera Replacement: passo 7, imagem 1 %32 Protocol Videodrone AP Camera Replacement: passo 7, imagem 2 %32 Protocol Videodrone AP Camera Replacement: passo 7, imagem 3 %32
    • Depress the tab to open the battery housing.
    • Disconnect the battery connectors
    • Remove the battery.
  8. Protocol Videodrone AP Camera Replacement: passo 8, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the four circuit board screws.
    • Remove circuit board.
  9. Protocol Videodrone AP Camera Replacement: passo 9, imagem 1 %32 Protocol Videodrone AP Camera Replacement: passo 9, imagem 2 %32
    • Remove the four battery housing screws with the Phillips #0 screwdriver.
    • Remove the battery housing to reveal the camera circuit board underneath.
  10. Protocol Videodrone AP Camera Replacement: passo 10, imagem 1 %32
    • Pull upwards on the strip to remove the camera out of its slot.
  11. Protocol Videodrone AP Camera Replacement: passo 11, imagem 1 %32
    • Remove camera circuit board from housing.
    • On the main circuit board, desolder the the connection points connecting to camera circuit board.
    • Four wires need to be desoldered. Colours include: Red, white, black and blue.
    • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
Conclusão
Karan Paranganat
Membro desde: 11/07/19
352 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S2-G2, Harley Fall 2019 Membro de IUPUI, Team S2-G2, Harley Fall 2019
IUPUI-HARLEY-F19S2G2
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 268
