Ir para o conteúdo principal
Protocol Videodrone AP Battery Wiring Replacement
O que você precisa
    1. Protocol Videodrone AP Battery Wiring  Replacement, Battery Wiring: passo 1, imagem 1 %32
      • Make sure the drone is turned off
      Pergunte ao FixBot
      Comentar
    2. Protocol Videodrone AP Battery Wiring  Replacement: passo 2, imagem 1 %32
      • Open the hatch and carefully pull out the battery to expose the cable connection
      Pergunte ao FixBot
      Comentar
    3. Protocol Videodrone AP Battery Wiring  Replacement: passo 3, imagem 1 %32 Protocol Videodrone AP Battery Wiring  Replacement: passo 3, imagem 2 %32
      • Carefully pull apart the cable connection
      Pergunte ao FixBot
      Comentar
    4. Protocol Videodrone AP Battery Wiring  Replacement: passo 4, imagem 1 %32 Protocol Videodrone AP Battery Wiring  Replacement: passo 4, imagem 2 %32
      • Unscrew the 4 screws from the bottom of the drone.
      • Unscrew the 8 screws connecting the propeller guards to the drone
      • Unscrew the four propeller screws.
      • One screw is hidden behind the screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Protocol Videodrone AP Battery Wiring  Replacement: passo 5, imagem 1 %32
      • Carefully remove faulty battery wiring from the drone
      Pergunte ao FixBot
      Comentar
    6. Protocol Videodrone AP Battery Wiring  Replacement: passo 6, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Feed through opening using tweezers to grasp the wire and carefully pull through.
      Pergunte ao FixBot
      Comentar
    7. Protocol Videodrone AP Battery Wiring  Replacement: passo 7, imagem 1 %32
      • Use the soldering iron to solder new wires to mother board. CAUTION: Soldering iron may get hot and cause minor burns if handled improperly.
      • Use this guide for how to solder: https://www.youtube.com/watch?v=QKbJxytE...
      Pergunte ao FixBot
      Comentar
    8. Protocol Videodrone AP Battery Wiring  Replacement: passo 8, imagem 1 %32
      • Reattach the battery and test for power by turning on the drone and look for the 4 LEDs turn on.
      Pergunte ao FixBot
      Comentar
Conclusão
All Done!
Uma outra pessoa concluiu este guia.
Serge
Membro desde: 09/26/17
340 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S2-G1, Passmore Fall 2017 Membro de USF Tampa, Team S2-G1, Passmore Fall 2017
USFT-PASSMORE-F17S2G1
4 Membros
Autoria de 3 guias
3Comentários do guia
Great explanation. Just wondering where to get the replacement piece. My drone has the black wire hanging by a single strand just outside the white connector. The red wire is in tact but I would need the whole part that attaches to the board and extends outside the drone to connect the battery to. Thanks
yasureok - Responder Compartilhar
Was wondering i think its charging the blue light flashes when plugged in but wont turn on. Wires look brand new
Michael Landry - Responder Compartilhar
I’m wondering the same thing, mine lights up blue when charging, wires look good but still no action.
Ryann Hunter - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 31
Ao todo: 2,193
