Introdução
This guide will demonstrate how to remove and replace the front camera on the Protocol Vento drone.
O que você precisa
To get into the drone, twelve total screws need to be removed:
Ten 5.7mm Phillips #000 screws from the bottom of the drone body.
Two 4.5mm Phillips #000 screws at the front of the drone.
Remove the two 4.9mm Phillips #000 screws securing the camera to the front of the drone body.
3 outras pessoas executaram este guia.
