Ir para o conteúdo principal
Protocol Slipstream WiFi Propeller Replacement
O que você precisa
    1. Protocol Slipstream WiFi Propeller Replacement, Propeller: passo 1, imagem 1 %32
      • Remove the 4.5 mm Philips #00 screw that holds the propeller in place.
      Pergunte ao FixBot
      Comentar
    2. Protocol Slipstream WiFi Propeller Replacement: passo 2, imagem 1 %32
      • Lift the propeller off the device
      • Note: When sliding on the new propeller, make sure to align the groove on the propeller with the shaft of the gear. If aligned correctly the propeller should slide on smoothly.
      • There are two different propellers that go on the device. Each propeller has a 3 or 4 written on it. Be sure to replace the propeller with a new propeller with the matching number.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 28
Ao todo: 474
