Ir para o conteúdo principal
Protocol Dronium Two Rechargeable Battery Replacement
O que você precisa
    1. Protocol Dronium Two Rechargeable Battery Replacement, Rechargeable Battery: passo 1, imagem 1 %32
      • Turn the drone off by moving the selector switch to the left.
      Pergunte ao FixBot
      Comentar
    2. Protocol Dronium Two Rechargeable Battery Replacement: passo 2, imagem 1 %32
      • On the underside of the drone, gently pull the battery compartment away from the drone.
      • Press down on the camera as shown to get a better grip.
      Pergunte ao FixBot
      Comentar
    3. Protocol Dronium Two Rechargeable Battery Replacement: passo 3, imagem 1 %32 Protocol Dronium Two Rechargeable Battery Replacement: passo 3, imagem 2 %32
      • If the power cable of the battery is connected to the drone, remove it by gently pulling it out.
      Pergunte ao FixBot
      Comentar
    4. Protocol Dronium Two Rechargeable Battery Replacement: passo 4, imagem 1 %32
      • Remove the battery from its compartment by sliding it out away from the drone.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 26
Ao todo: 673
