Introdução
If your drone does not respond to the controller, the antenna could be the issue. The following guide will help you to replace the antenna in the controller.
O que você precisa
Remove the six 8.8 mm screws located on the back panel of the controller using a Phillips 000 screwdriver.
Uma outra pessoa concluiu este guia.
