Ir para o conteúdo principal
ProntoTec Axius Screen Replacement
O que você precisa
    1. ProntoTec Axius Screen Replacement, Screen: passo 1, imagem 1 %32
      • Make sure the device is completely turned off before you begin taking it apart to avoid risk of electrocution.
      • Place the tablet face-up on a flat table
      Pergunte ao FixBot
      Comentar
    2. ProntoTec Axius Screen Replacement: passo 2, imagem 1 %32
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      Pergunte ao FixBot
      Comentar
    3. ProntoTec Axius Screen Replacement: passo 3, imagem 1 %32
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      Pergunte ao FixBot
      Comentar
    4. ProntoTec Axius Screen Replacement: passo 4, imagem 1 %32
      • Remove all of the yellow tape that is on the device with the spudger.
      • Be careful not to cut any wires that are under the tapes.
      Pergunte ao FixBot
      Comentar
    5. ProntoTec Axius Screen Replacement: passo 5, imagem 1 %32 ProntoTec Axius Screen Replacement: passo 5, imagem 2 %32
      • Use the flat end of the spudger to gently pry the battery from the back of the screen.
      Pergunte ao FixBot
      Comentar
    6. ProntoTec Axius Screen Replacement: passo 6, imagem 1 %32 ProntoTec Axius Screen Replacement: passo 6, imagem 2 %32
      • Use a spudger to lift all the ribbon cable clamps
      • Detach all three ribbon cables from the clamps
      Pergunte ao FixBot
      Comentar
    7. ProntoTec Axius Screen Replacement: passo 7, imagem 1 %32 ProntoTec Axius Screen Replacement: passo 7, imagem 2 %32 ProntoTec Axius Screen Replacement: passo 7, imagem 3 %32
      • Using a Phillips screwdriver (PH00), unscrew the motherboard from the device
      Pergunte ao FixBot
      Comentar
    8. ProntoTec Axius Screen Replacement: passo 8, imagem 1 %32 ProntoTec Axius Screen Replacement: passo 8, imagem 2 %32 ProntoTec Axius Screen Replacement: passo 8, imagem 3 %32
      Ferramenta utilizada neste passo:
      Heavy-Duty Spudger
      • Use the flat end of the metal spudger to remove the battery from the back of the screen of the device.
      • Avoid using metal when prying off the battery. For serious prying power, try using the heavy-duty plastic spudger.
      Pergunte ao FixBot
      Comentar
    9. ProntoTec Axius Screen Replacement: passo 9, imagem 1 %32
      • Remove the orange tab from the back of the screen as shown in the picture
      Pergunte ao FixBot
      Comentar
    10. ProntoTec Axius Screen Replacement: passo 10, imagem 1 %32 ProntoTec Axius Screen Replacement: passo 10, imagem 2 %32
      • Use the flat end of the metal spudger to unclip and remove the screen from the casing.
      Pergunte ao FixBot
      Comentar
Conclusão
Antonio Irons
Membro desde: 10/20/16
441 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-3, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 28
Ao todo: 607
