Ir para o conteúdo principal
ProntoTec Axius Camera Replacement
O que você precisa
    1. ProntoTec Axius Camera Replacement, Camera: passo 1, imagem 1 %32
      • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
      • Place the tablet face-up on a flat table.
      Pergunte ao FixBot
      Comentar
    2. ProntoTec Axius Camera Replacement: passo 2, imagem 1 %32
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      Pergunte ao FixBot
      Comentar
    3. ProntoTec Axius Camera Replacement: passo 3, imagem 1 %32
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      Pergunte ao FixBot
      Comentar
    4. ProntoTec Axius Camera Replacement: passo 4, imagem 1 %32
      • Remove only the yellow tape that touches the battery.
      • Be careful not to cut or damage the wires (red and black) that are under the yellow tape.'
      Pergunte ao FixBot
      Comentar
    5. ProntoTec Axius Camera Replacement: passo 5, imagem 1 %32 ProntoTec Axius Camera Replacement: passo 5, imagem 2 %32
      • Use the flat end of the spudger to gently pry the top left corner battery from the back of the screen in order to access the camera.
      Pergunte ao FixBot
      Comentar
    6. ProntoTec Axius Camera Replacement: passo 6, imagem 1 %32 ProntoTec Axius Camera Replacement: passo 6, imagem 2 %32 ProntoTec Axius Camera Replacement: passo 6, imagem 3 %32
      • Use the spudger to lift the black clamp as shown in the photo to disconnect the camera from the motherboard.
      Pergunte ao FixBot
      Comentar
    7. ProntoTec Axius Camera Replacement: passo 7, imagem 1 %32 ProntoTec Axius Camera Replacement: passo 7, imagem 2 %32
      • Disconet the camera from the motherboard.
      • Pull the camera from the back of the screen.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Antonio Irons
Membro desde: 10/20/16
441 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-3, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 10
Últimos 30 dias: 29
Ao todo: 456
