Ir para o conteúdo principal
ProntoTec Axius Battery Replacement
O que você precisa
    1. ProntoTec Axius Battery Replacement, Battery: passo 1, imagem 1 %32
      • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
      • Place the tablet face-up on a flat table
      Pergunte ao FixBot
      Comentar
    2. ProntoTec Axius Battery Replacement: passo 2, imagem 1 %32
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      Pergunte ao FixBot
      Comentar
    3. ProntoTec Axius Battery Replacement: passo 3, imagem 1 %32
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      Pergunte ao FixBot
      Comentar
    4. ProntoTec Axius Battery Replacement: passo 4, imagem 1 %32
      • Using a spudger remove all the tapes that touches the battery.
      • Be careful not to cute any wires that are under the tapes
      Pergunte ao FixBot
      Comentar
    5. ProntoTec Axius Battery Replacement: passo 5, imagem 1 %32
      • Using a soldering iron, heat up the contact point of the red wire from the battery and the motherboard.
      • When the solder begins to melt, use pliers to gently pull the wire from the motherboard
      • Don't leave the soldering iron too long on top of the wire so it doesn't melt any other component in the motherboard or surrounding the area.
      Pergunte ao FixBot
      Comentar
    6. ProntoTec Axius Battery Replacement: passo 6, imagem 1 %32
      • Repeat Step 5 on the black wire connecting the battery to the motherboard as shown in the photo.
      Pergunte ao FixBot
      Comentar
    7. ProntoTec Axius Battery Replacement: passo 7, imagem 1 %32 ProntoTec Axius Battery Replacement: passo 7, imagem 2 %32
      • Using a spudger, gently pry the battery from the back of the screen to remove it from the device.
      Pergunte ao FixBot
      Comentar
Conclusão
Antonio Irons
Membro desde: 10/20/16
441 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-3, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 603
