Ir para o conteúdo principal
ProScan PLT7223G Screen Replacement
O que você precisa
    1. ProScan PLT7223G Screen Replacement, Screen: passo 1, imagem 1 %32
      • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
      Pergunte ao FixBot
      Comentar
    2. ProScan PLT7223G Screen Replacement: passo 2, imagem 1 %32
      • Use the blue plastic opening tool to pry open the tablet.
      • You will hear popping sounds. That's okay.
      • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
      Pergunte ao FixBot
      Comentar
    3. ProScan PLT7223G Screen Replacement: passo 3, imagem 1 %32
      • Remove three 4 mm screws from the motherboard.
      Pergunte ao FixBot
      Comentar
    4. ProScan PLT7223G Screen Replacement: passo 4, imagem 1 %32
      • Insert a spudger under the black tape that connects the silver wire to the interior of the front panel
      • Pull back the black tape with the spudger until it can be lifted up with your fingers.
      • Use your fingers to grab and lift the remainder of the black tape from device panel.
      Pergunte ao FixBot
      Comentar
    5. ProScan PLT7223G Screen Replacement: passo 5, imagem 1 %32
      • Use a plastic opening tool to push back the ZIF connector to release the ribbon wire on the motherboard.
      Pergunte ao FixBot
      Comentar
    6. ProScan PLT7223G Screen Replacement: passo 6, imagem 1 %32
      • Insert an opening tool underneath the silver base of the internal device element.
      • Use the opening tool to pry the element out of the case that holds the screen.
      • You will need to release a number of clips in order to remove the screen.
      • Be careful not to damage the motherboard or battery as you go.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 2,106
