Ir para o conteúdo principal
ProScan PLT7223G Battery Replacement
O que você precisa
    1. ProScan PLT7223G Battery Replacement, Battery: passo 1, imagem 1 %32
      • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
      Pergunte ao FixBot
      Comentar
    2. ProScan PLT7223G Battery Replacement: passo 2, imagem 1 %32
      • Use the blue plastic opening tool to pry open the tablet.
      • You will hear popping sounds. That's okay.
      • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
      Pergunte ao FixBot
      Comentar
    3. ProScan PLT7223G Battery Replacement: passo 3, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Use a soldering tool and tweezers to remove the black and red wire from the motherboard.
      • Be sure to pay attention to where each wire goes so that you attach them in the correct order when reassembling the device.
      • Soldering tool will get hot, handle with care.
      Pergunte ao FixBot
      Comentar
    4. ProScan PLT7223G Battery Replacement: passo 4, imagem 1 %32
      • Use a spudger to remove the black tape from the battery.
      Pergunte ao FixBot
      Comentar
    5. ProScan PLT7223G Battery Replacement: passo 5, imagem 1 %32
      • Using the flat end of a spudger, carefully separate the battery from the base of the device.
      • There is an adhesive holding the charger in place.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
2Comentários do guia
what is the number of the replacement battery??
florcomm - Responder Compartilhar
How will I know if my proscan tablet battery is no good once I remove it
Genica Harmon - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 27
Ao todo: 4,741
