Ir para o conteúdo principal
ProScan PLT7050 Camera Replacement
O que você precisa
    1. ProScan PLT7050 Camera Replacement, Open Device: passo 1, imagem 1 %32
      • Make sure device is unplugged and turned off while working on the device.
      • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. ProScan PLT7050 Camera Replacement: passo 2, imagem 1 %32
      • Use the plastic opening tools to pry the back of the tablet open.
      • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
      • May be helpful if you start by the microSD slot.
      Pergunte ao FixBot
      Comentar
    1. ProScan PLT7050 Camera Replacement, Camera: passo 3, imagem 1 %32
      • Remove the black tape carefully.
      Pergunte ao FixBot
      Comentar
    2. ProScan PLT7050 Camera Replacement: passo 4, imagem 1 %32
      • Use the plastic opening tool to open the ZIF connector tab to release the camera's ribbon cable.
      Pergunte ao FixBot
      Comentar
    3. ProScan PLT7050 Camera Replacement: passo 5, imagem 1 %32
      • Remove the camera's ribbon cable.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 387
