Ir para o conteúdo principal
PowerBook G4 Titanium Mercury Display Replacement
O que você precisa
  1. PowerBook G4 Titanium Mercury Display Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove the battery.
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    Pergunte ao FixBot
    Comentar
  2. PowerBook G4 Titanium Mercury Display Replacement: passo 2, imagem 1 %32
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
    Pergunte ao FixBot
    Comentar
  3. PowerBook G4 Titanium Mercury Display Replacement: passo 3, imagem 1 %32
    • Your laptop should look approximately like this.
    Pergunte ao FixBot
    Comentar
  4. PowerBook G4 Titanium Mercury Display Replacement, RAM: passo 4, imagem 1 %32
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • Repeat this process if a second RAM chip is installed.
    Pergunte ao FixBot
    Comentar
    • Turn the G4 over.
    • Remove the eight Phillips screws from the lower case.
    Pergunte ao FixBot
    Comentar
  5. PowerBook G4 Titanium Mercury Display Replacement: passo 6, imagem 1 %32
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
    Pergunte ao FixBot
    Comentar
  6. PowerBook G4 Titanium Mercury Display Replacement: passo 7, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  7. PowerBook G4 Titanium Mercury Display Replacement, Airport Card: passo 8, imagem 1 %32
    • Skip this step if your computer does not have an Airport card.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
    Pergunte ao FixBot
    Comentar
  8. PowerBook G4 Titanium Mercury Display Replacement, Hard Drive: passo 9, imagem 1 %32
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
    Pergunte ao FixBot
    Comentar
  9. PowerBook G4 Titanium Mercury Display Replacement: passo 10, imagem 1 %32
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
    Pergunte ao FixBot
    Comentar
  10. PowerBook G4 Titanium Mercury Display Replacement: passo 11, imagem 1 %32
    • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
    Pergunte ao FixBot
    Comentar
  11. PowerBook G4 Titanium Mercury Display Replacement: passo 12, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  12. PowerBook G4 Titanium Mercury Display Replacement, DVD Drive: passo 13, imagem 1 %32
    • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out.
    • Carefully peel the adhesive strip away from the DVD drive. The plastic dust shield covering the DVD drive is easily damaged. Try to start at the four corners and work toward the center.
    Pergunte ao FixBot
    Comentar
  13. PowerBook G4 Titanium Mercury Display Replacement: passo 14, imagem 1 %32
    • Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
    • The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
    Pergunte ao FixBot
    Comentar
  14. PowerBook G4 Titanium Mercury Display Replacement: passo 15, imagem 1 %32
    • Turn the G4 over.
    • Disconnect both orange ribbon cables from the logic board using a spudger or the tip of your finger.
    Pergunte ao FixBot
    Comentar
  15. PowerBook G4 Titanium Mercury Display Replacement: passo 16, imagem 1 %32
    • Remove the DVD drive by lifting the right edge up and out of the computer.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    Pergunte ao FixBot
    Comentar
  16. PowerBook G4 Titanium Mercury Display Replacement, Modem: passo 17, imagem 1 %32
    • Turn the G4 over.
    • Using a 5 mm nut driver or needle-nose pliers, remove the hex nut from the modem.
    Pergunte ao FixBot
    Comentar
  17. PowerBook G4 Titanium Mercury Display Replacement: passo 18, imagem 1 %32
    • Lift the modem out by pulling up and to the right.
    • The plastic shielding on the modem may catch on the computer's case. Rocking the modem from side to side will help free the modem.
    Pergunte ao FixBot
    Comentar
  18. PowerBook G4 Titanium Mercury Display Replacement: passo 19, imagem 1 %32
    • Disconnect the connector cable from the modem.
    Pergunte ao FixBot
    Comentar
  19. PowerBook G4 Titanium Mercury Display Replacement, PMU: passo 20, imagem 1 %32
    • Turn the G4 over.
    • Peel the orange tape away from the three connectors on the PMU board. Leave this tape in place so you can reuse it when reassembling the G4.
    • Disconnect the two orange cables and one multicolored cable from the PMU.
    Pergunte ao FixBot
    Comentar
  20. PowerBook G4 Titanium Mercury Display Replacement: passo 21, imagem 1 %32
    • Lift up on the silver metal clip to free the PMU from the casing.
    • Remove the PMU rotating it clockwise and pulling up.
    Pergunte ao FixBot
    Comentar
  21. PowerBook G4 Titanium Mercury Display Replacement: passo 22, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  22. PowerBook G4 Titanium Mercury Display Replacement, Logic Board: passo 23, imagem 1 %32
    • Turn the G4 over and rest it on a soft cloth.
    • Disconnect the multicolored fan connector and battery connector from the logic board.
    • Disconnect the orange PC card cage connector from the logic board.
    Pergunte ao FixBot
    Comentar
  23. PowerBook G4 Titanium Mercury Display Replacement: passo 24, imagem 1 %32
    • Remove the single T8 Torx screw located next to the PC Card cage.
    Pergunte ao FixBot
    Comentar
  24. PowerBook G4 Titanium Mercury Display Replacement: passo 25, imagem 1 %32
    • Turn the G4 over.
    • Remove the two T8 Torx screws from the middle of the logic board.
    Pergunte ao FixBot
    Comentar
  25. PowerBook G4 Titanium Mercury Display Replacement: passo 26, imagem 1 %32
    • Disconnect the four indicated connectors from the logic board, removing tape as necessary.
    Pergunte ao FixBot
    Comentar
  26. PowerBook G4 Titanium Mercury Display Replacement: passo 27, imagem 1 %32
    • Carefully lift the logic board up and pull it away from you. The logic board may catch on the back panel ports liner. If this occurs, use a spudger or non-metal tool to free the logic board.
    • This step requires some force, but if the logic board will not come up, make sure you have removed all screws and connectors necessary.
    • Remove the logic board from the computer.
    Pergunte ao FixBot
    Comentar
  27. PowerBook G4 Titanium Mercury Display Replacement: passo 28, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  28. PowerBook G4 Titanium Mercury Display Replacement, PC Card Cage: passo 29, imagem 1 %32
    • Remove the two T8 Torx screws that secure the PC Card cage.
    Pergunte ao FixBot
    Comentar
  29. PowerBook G4 Titanium Mercury Display Replacement: passo 30, imagem 1 %32
    • Remove the PC Card cage by pulling it to the right and twisting slightly toward you.
    Pergunte ao FixBot
    Comentar
  30. PowerBook G4 Titanium Mercury Display Replacement, Display: passo 31, imagem 1 %32
    • Performing the following steps incorrectly can easily damage the display and render it inoperable. The multicolor display data cable is especially fragile.
    • Position the display at a 45 degree angle and rest the computer on a cloth with the back panel ports facing up. Remove the two T8 Torx screws from each clutch cover.
    Pergunte ao FixBot
    Comentar
  31. PowerBook G4 Titanium Mercury Display Replacement: passo 32, imagem 1 %32
    • Close the display and pull off both clutch covers. You can use a non-metal flathead screwdriver if the clutch covers do not come off easily.
    Pergunte ao FixBot
    Comentar
  32. PowerBook G4 Titanium Mercury Display Replacement: passo 33, imagem 1 %32
    • Open the display to a 90 degree angle. Rest the trackpad face down on the work surface and allow the display to hang over the edge. If possible, adjust your chair or work surface height so the display will rest on your legs and the upper case will lie flat on the work surface. If you cannot make this adjustment, you can remove the display with the screen closed. We recommend removing the display with the screen open in order to avoid changing the position of the hinges once the display has been removed.
    Pergunte ao FixBot
    Comentar
  33. PowerBook G4 Titanium Mercury Display Replacement: passo 34, imagem 1 %32
    • Remove the four Phillips screws which fasten the display to the upper case.
    • The screw closest to the display data cable has a tapered head.
    Pergunte ao FixBot
    Comentar
  34. PowerBook G4 Titanium Mercury Display Replacement: passo 35, imagem 1 %32
    • Lift up the metal brackets on either side of the upper case.
    • Disconnect the inverter cable and carefully thread it through the slot in the upper case.
    Pergunte ao FixBot
    Comentar
  35. PowerBook G4 Titanium Mercury Display Replacement: passo 36, imagem 1 %32
    • Carefully thread the display and backlight cables individually through the slot in the upper case. Be very careful with the display cable and it is easily damaged.
    • Remove the display assembly.
    Pergunte ao FixBot
    Comentar
  36. PowerBook G4 Titanium Mercury Display Replacement: passo 37, imagem 1 %32
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 76
Ao todo: 18,722
