Ir para o conteúdo principal
PowerBook G4 Titanium Mercury DVD Drive Replacement
O que você precisa
  1. PowerBook G4 Titanium Mercury DVD Drive Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove the battery.
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    Pergunte ao FixBot
    Comentar
  2. PowerBook G4 Titanium Mercury DVD Drive Replacement: passo 2, imagem 1 %32
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
    Pergunte ao FixBot
    Comentar
  3. PowerBook G4 Titanium Mercury DVD Drive Replacement: passo 3, imagem 1 %32
    • Your laptop should look approximately like this.
    Pergunte ao FixBot
    Comentar
    • Turn the G4 over.
    • Remove the eight Phillips screws from the lower case.
    Pergunte ao FixBot
    Comentar
  4. PowerBook G4 Titanium Mercury DVD Drive Replacement: passo 5, imagem 1 %32
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
    Pergunte ao FixBot
    Comentar
  5. PowerBook G4 Titanium Mercury DVD Drive Replacement: passo 6, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  6. PowerBook G4 Titanium Mercury DVD Drive Replacement, DVD Drive: passo 7, imagem 1 %32
    • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out.
    • Carefully peel the adhesive strip away from the DVD drive. The plastic dust shield covering the DVD drive is easily damaged. Try to start at the four corners and work toward the center.
    Pergunte ao FixBot
    Comentar
  7. PowerBook G4 Titanium Mercury DVD Drive Replacement: passo 8, imagem 1 %32
    • Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
    • The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
    Pergunte ao FixBot
    Comentar
  8. PowerBook G4 Titanium Mercury DVD Drive Replacement: passo 9, imagem 1 %32
    • Turn the G4 over.
    • Disconnect both orange ribbon cables from the logic board using a spudger or the tip of your finger.
    Pergunte ao FixBot
    Comentar
  9. PowerBook G4 Titanium Mercury DVD Drive Replacement: passo 10, imagem 1 %32
    • Remove the DVD drive by lifting the right edge up and out of the computer.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 53
Ao todo: 12,831
