Ir para o conteúdo principal
PowerBook G4 Titanium DVI RAM Replacement
O que você precisa
  1. PowerBook G4 Titanium DVI RAM Replacement, Battery: passo 1, imagem 1 %32 PowerBook G4 Titanium DVI RAM Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
    Pergunte ao FixBot
    Comentar
  2. PowerBook G4 Titanium DVI RAM Replacement, Keyboard: passo 2, imagem 1 %32
    • Turn the keyboard locking screw located in the middle of the keyboard so that it is parallel to the space bar. A half turn from parallel to parallel will unlock it. Another half turn will lock it again.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    Pergunte ao FixBot
    Comentar
  3. PowerBook G4 Titanium DVI RAM Replacement: passo 3, imagem 1 %32
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
    Pergunte ao FixBot
    Comentar
  4. PowerBook G4 Titanium DVI RAM Replacement: passo 4, imagem 1 %32
    • Your laptop should look approximately like this.
    Pergunte ao FixBot
    Comentar
  5. PowerBook G4 Titanium DVI RAM Replacement, RAM: passo 5, imagem 1 %32
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • Repeat this process if a second RAM chip is installed.
    Pergunte ao FixBot
    Comentar
Conclusão
24 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 12
Últimos 30 dias: 51
Ao todo: 15,401
