Ir para o conteúdo principal
PowerBook G4 Titanium DVI Latch Replacement
O que você precisa
  1. PowerBook G4 Titanium DVI Latch Replacement, Battery: passo 1, imagem 1 %32 PowerBook G4 Titanium DVI Latch Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
    Pergunte ao FixBot
    Comentar
  2. PowerBook G4 Titanium DVI Latch Replacement, Lower Case: passo 2, imagem 1 %32 PowerBook G4 Titanium DVI Latch Replacement, Lower Case: passo 2, imagem 2 %32
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
    Pergunte ao FixBot
    Comentar
  3. PowerBook G4 Titanium DVI Latch Replacement, Hard Drive: passo 3, imagem 1 %32
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
    Pergunte ao FixBot
    Comentar
  4. PowerBook G4 Titanium DVI Latch Replacement: passo 4, imagem 1 %32
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
    Pergunte ao FixBot
    Comentar
  5. PowerBook G4 Titanium DVI Latch Replacement: passo 5, imagem 1 %32
    • Remove the hard drive by lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
    Pergunte ao FixBot
    Comentar
  6. PowerBook G4 Titanium DVI Latch Replacement: passo 6, imagem 1 %32
    • Your laptop should look approximately like this.
    Pergunte ao FixBot
    Comentar
  7. PowerBook G4 Titanium DVI Latch Replacement, Latch: passo 7, imagem 1 %32
    • Use your thumbnails to push in and then lift the two fingers of the latch clip over the restraining bar.
    Pergunte ao FixBot
    Comentar
  8. PowerBook G4 Titanium DVI Latch Replacement: passo 8, imagem 1 %32
    • Now use your index fingers' nails to pull at the "elbows" of the clip, rotating it upward approximately 90 degrees, or until the latch pops out
    Pergunte ao FixBot
    Comentar
  9. PowerBook G4 Titanium DVI Latch Replacement: passo 9, imagem 1 %32
    • Insert the new latch by rotating the clip up and pushing the latch into place. Then rotate the clip back down, pushing in at the area where the clip bends around the latch. Make sure to insert the clip fingers back into their slots.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 43
Ao todo: 8,614
