Introdução
Connects the battery to the logic board.
O que você precisa
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Remove the following ten screws:
Two 14.7 mm shouldered Phillips.
Three 12.3 mm Phillips.
One 3.8 mm T8 Torx.
One 6.8 mm T8 Torx.
Three 1.3 mm Phillips.
Close your PowerBook, minding any cables that may interfere, and flip it over.
Disconnect the power cable connector by pulling it straight away from its socket on the logic board.
