Ir para o conteúdo principal
PowerBook G3 Wallstreet Keyboard Replacement
O que você precisa
  1. PowerBook G3 Wallstreet Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove both expansion bay modules using the levers on the front of the computer.
    • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
    • Pull the tabs toward yourself and the keyboard will pop up.
    Pergunte ao FixBot
    Comentar
  2. PowerBook G3 Wallstreet Keyboard Replacement: passo 2, imagem 1 %32
    • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Rest the keyboard on the trackpad.
    Pergunte ao FixBot
    Comentar
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    Pergunte ao FixBot
    Comentar
  3. PowerBook G3 Wallstreet Keyboard Replacement: passo 4, imagem 1 %32
    • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
    Pergunte ao FixBot
    Comentar
  4. PowerBook G3 Wallstreet Keyboard Replacement: passo 5, imagem 1 %32
    • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Once the strain relief cables are free, lift the keyboard off.
    Pergunte ao FixBot
    Comentar
  5. PowerBook G3 Wallstreet Keyboard Replacement: passo 6, imagem 1 %32
    • Your laptop should look approximately like this.
    Pergunte ao FixBot
    Comentar
Conclusão
9 outras pessoas executaram este guia.
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
3Comentários do guia
The first iFixit guide?
ljcool2006 - Responder Compartilhar
Yes sir! (text minimum)
guardian10 - Responder Compartilhar
Yes yes yes yes
Lol - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 27
Últimos 30 dias: 108
Ao todo: 22,393
