Ir para o conteúdo principal
PowerBook G3 Pismo Hard Drive Replacement
O que você precisa
  1. PowerBook G3 Pismo Hard Drive Replacement, Keyboard: passo 1, imagem 1 %32
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
    Pergunte ao FixBot
  2. PowerBook G3 Pismo Hard Drive Replacement: passo 2, imagem 1 %32
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
    Pergunte ao FixBot
  3. PowerBook G3 Pismo Hard Drive Replacement: passo 3, imagem 1 %32
    • Your laptop should look approximately like this.
    Pergunte ao FixBot
  4. PowerBook G3 Pismo Hard Drive Replacement, Heat Shield: passo 4, imagem 1 %32
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
    Pergunte ao FixBot
  5. PowerBook G3 Pismo Hard Drive Replacement: passo 5, imagem 1 %32
    Pergunte ao FixBot
  6. PowerBook G3 Pismo Hard Drive Replacement, Airport Card: passo 6, imagem 1 %32
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
    Pergunte ao FixBot
  7. PowerBook G3 Pismo Hard Drive Replacement: passo 7, imagem 1 %32
    • Disconnect the antenna cable from the Airport card.
    Pergunte ao FixBot
  8. PowerBook G3 Pismo Hard Drive Replacement, Heat Sink: passo 8, imagem 1 %32
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
    Pergunte ao FixBot
  9. PowerBook G3 Pismo Hard Drive Replacement: passo 9, imagem 1 %32
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
    Pergunte ao FixBot
  10. PowerBook G3 Pismo Hard Drive Replacement, Processor: passo 10, imagem 1 %32
    • Grasp the plastic tab on the processor's right side and pull it directly up.
    • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
    Pergunte ao FixBot
  11. PowerBook G3 Pismo Hard Drive Replacement: passo 11, imagem 1 %32
    Pergunte ao FixBot
  12. PowerBook G3 Pismo Hard Drive Replacement, Hard Drive: passo 12, imagem 1 %32
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
    Pergunte ao FixBot
  13. PowerBook G3 Pismo Hard Drive Replacement: passo 13, imagem 1 %32
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
    Pergunte ao FixBot
  14. PowerBook G3 Pismo Hard Drive Replacement: passo 14, imagem 1 %32
    Pergunte ao FixBot
  15. PowerBook G3 Pismo Hard Drive Replacement, Hard Drive: passo 15, imagem 1 %32
    • Remove the four black Torx screws located at the four corners of the hard drive bracket.
    Pergunte ao FixBot
  16. PowerBook G3 Pismo Hard Drive Replacement: passo 16, imagem 1 %32
    • Pull the connector cable out from the hard drive, applying even pressure while gently rocking up and down.
    • Be very careful to apply even pressure when removing the cable. If you torque too hard to either side, you may damage or destroy the hard drive's connector pins, rendering your data inaccessible.
    Pergunte ao FixBot
Conclusão
30 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
4Comentários do guia
In my humble opinion steps 6-12 are unnecessary. You can take out the harddrive cage without removing the processor card. Granted, you have to replace the drive in the cage while the cage is still connected to the PowerBook, but at the same time it saves you from having to remove/reapply the thermal paste on the CPU. I think for most of us that's a fair trade-off.
Erik D - Responder Compartilhar
The Torx-T8 is unnecessary; eliminate step 8 and 9 unless you explicitly haven't yet changed the thermal interface material on your processor.
Removing the phillips-head screw in the area of the heatsink above the modem card (The yellow-circled screw in step 8's photo) and then lifting the plastic tab on the processor as shown in step 10, while sliding the processor slightly to the right, will permit a clean removal. Reverse procedure is to slide the processor in so that the tabs engage the metal cage, and then applying pressure to the processor board (remove RAM in the top slot first!) to engage the LIF connection.
Hope this saves someone a few minutes of rooting around for a torx driver.
peanuthorst - Responder Compartilhar
I can confirm, you need not to remove the processor card. Remove the heat shield, lay down an antistatic foil on the processor card, carefully lift up the drive cage on the left side. Disconnect the drive on the right side of cage, remove the 4 screws holding the drive.
My Pismo had an old 12GB drive, changed it to an IDE SSD drive (KingSpec 64GB). Now I have 3 partions: MacOSX 10.2, MacOSX10.4.11 and MacOS9.2.2. It works very well without any problems!
Remember: must be Apple partions, not GUID!
Stefan Richter - Responder Compartilhar
Not only does this work great, I can confirm that in the year of our lord 2022 you can use an mSATA drive with an mSATA to IDE adapter in the Pismo. Search on 68kmla for the information if you want to know 100% the drive you’re trying is going to work.
I can’t believe my Pismo has a 128G SSD in it! It’s faster, and though I don’t carry it around, it’s a little lighter too.
(and also, THANK YOU Erik, steps 6-12 aren’t needed just to swap the HDD, though I do recommend thermal paste of course for anyone who is able to do it).
Alex K - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 143
Ao todo: 24,592
