Ir para o conteúdo principal
PowerBook G3 Lombard RAM Replacement
O que você precisa
  1. PowerBook G3 Lombard RAM Replacement, Keyboard: passo 1, imagem 1 %32
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
    Pergunte ao FixBot
    Comentar
  2. PowerBook G3 Lombard RAM Replacement: passo 2, imagem 1 %32
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
    Pergunte ao FixBot
    Comentar
  3. PowerBook G3 Lombard RAM Replacement: passo 3, imagem 1 %32
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
    Pergunte ao FixBot
    Comentar
  4. PowerBook G3 Lombard RAM Replacement, Heat Shield: passo 4, imagem 1 %32
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
    Pergunte ao FixBot
    Comentar
  5. PowerBook G3 Lombard RAM Replacement: passo 5, imagem 1 %32
    • Lift the heat shield up and pull it toward you.
    Pergunte ao FixBot
    Comentar
  6. PowerBook G3 Lombard RAM Replacement: passo 6, imagem 1 %32
    • Your laptop should look approximately like this.
    Pergunte ao FixBot
    Comentar
  7. PowerBook G3 Lombard RAM Replacement, PRAM Battery: passo 7, imagem 1 %32
    • Pull the battery cable directly up from the logic board.
    Pergunte ao FixBot
    Comentar
  8. PowerBook G3 Lombard RAM Replacement: passo 8, imagem 1 %32
    • Remove the battery from its holder by pulling up and to the left.
    Pergunte ao FixBot
    Comentar
  9. PowerBook G3 Lombard RAM Replacement, Modem: passo 9, imagem 1 %32
    • Remove the two silver Phillips screws from the modem.
    Pergunte ao FixBot
    Comentar
  10. PowerBook G3 Lombard RAM Replacement: passo 10, imagem 1 %32
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
    Pergunte ao FixBot
    Comentar
  11. PowerBook G3 Lombard RAM Replacement: passo 11, imagem 1 %32
    • Disconnect the cable from the right side of the modem.
    Pergunte ao FixBot
    Comentar
  12. PowerBook G3 Lombard RAM Replacement: passo 12, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  13. PowerBook G3 Lombard RAM Replacement, Processor: passo 13, imagem 1 %32
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    Pergunte ao FixBot
    Comentar
  14. PowerBook G3 Lombard RAM Replacement: passo 14, imagem 1 %32
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
    Pergunte ao FixBot
    Comentar
  15. PowerBook G3 Lombard RAM Replacement: passo 15, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  16. PowerBook G3 Lombard RAM Replacement, RAM: passo 16, imagem 1 %32
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • There are RAM slots on both sides of the processor. We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 41
Ao todo: 9,211
