Ir para o conteúdo principal
PowerBook 3400 M3553 Keyboard Replacement
O que você precisa
  1. PowerBook 3400 M3553 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
    Pergunte ao FixBot
    Comentar
  2. PowerBook 3400 M3553 Keyboard Replacement: passo 2, imagem 1 %32 PowerBook 3400 M3553 Keyboard Replacement: passo 2, imagem 2 %32
    • Hold the button on the front left side and slide the battery out.
    Pergunte ao FixBot
    Comentar
  3. PowerBook 3400 M3553 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
    Pergunte ao FixBot
    Comentar
  4. PowerBook 3400 M3553 Keyboard Replacement: passo 4, imagem 1 %32 PowerBook 3400 M3553 Keyboard Replacement: passo 4, imagem 2 %32 PowerBook 3400 M3553 Keyboard Replacement: passo 4, imagem 3 %32
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
    Pergunte ao FixBot
    Comentar
  5. PowerBook 3400 M3553 Keyboard Replacement: passo 5, imagem 1 %32 PowerBook 3400 M3553 Keyboard Replacement: passo 5, imagem 2 %32
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 24-59, Amido Spring 2011 Membro de Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 2,724
