Ir para o conteúdo principal
PowerA Spectra Infinity Enhanced Bumpers Replacement
O que você precisa
  1. PowerA Spectra Infinity Enhanced Bumpers Replacement, Motherboard: passo 1, imagem 1 %32 PowerA Spectra Infinity Enhanced Bumpers Replacement, Motherboard: passo 1, imagem 2 %32
    • Flip the controller so the back is facing up.
    Pergunte ao FixBot
    Comentar
  2. PowerA Spectra Infinity Enhanced Bumpers Replacement: passo 2, imagem 1 %32
    • Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. PowerA Spectra Infinity Enhanced Bumpers Replacement: passo 3, imagem 1 %32 PowerA Spectra Infinity Enhanced Bumpers Replacement: passo 3, imagem 2 %32
    • Unlock the trigger locks before removing the backplate.
    • This will make taking the plate off easier.
    • Use your fingers and carefully remove the backplate.
    Pergunte ao FixBot
    Comentar
  4. PowerA Spectra Infinity Enhanced Bumpers Replacement: passo 4, imagem 1 %32
    • Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. PowerA Spectra Infinity Enhanced Bumpers Replacement: passo 5, imagem 1 %32 PowerA Spectra Infinity Enhanced Bumpers Replacement: passo 5, imagem 2 %32
    • Use your hand to separate the motherboard from the face plate.
    Pergunte ao FixBot
    Comentar
  6. PowerA Spectra Infinity Enhanced Bumpers Replacement, Bumpers: passo 6, imagem 1 %32
    • Remove two 10 mm screws holding the bumper to the faceplate using a Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  7. PowerA Spectra Infinity Enhanced Bumpers Replacement: passo 7, imagem 1 %32 PowerA Spectra Infinity Enhanced Bumpers Replacement: passo 7, imagem 2 %32
    • Remove the single 7.9 mm screw holding the bumpers to the faceplate using a Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  8. PowerA Spectra Infinity Enhanced Bumpers Replacement: passo 8, imagem 1 %32
    • Remove the freed bumpers from the faceplate.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Kevyn Jorge
Membro desde: 03/22/24
1.018 Reputação
Autoria de 6 guias
Equipe
3Comentários do guia
okay but where can I get a replacement part from, I've spent ages looking and cant find one anywhere
Tom Radda - Responder Compartilhar
Do you sell replacement parts?
Everett - Responder Compartilhar
Replacement bumpers link?
Daniel Skerritt - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 96
Ao todo: 2,260
