Ir para o conteúdo principal
PowerA Fusion Controller For Xbox One Headphone Jack Replacement
O que você precisa
  1. PowerA Fusion Controller For Xbox One Headphone Jack Replacement, Headphone Jack: passo 1, imagem 1 %32 PowerA Fusion Controller For Xbox One Headphone Jack Replacement, Headphone Jack: passo 1, imagem 2 %32 PowerA Fusion Controller For Xbox One Headphone Jack Replacement, Headphone Jack: passo 1, imagem 3 %32
    • Remove the (9) nine 9.2mm screws (circled in red) with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. PowerA Fusion Controller For Xbox One Headphone Jack Replacement: passo 2, imagem 1 %32 PowerA Fusion Controller For Xbox One Headphone Jack Replacement: passo 2, imagem 2 %32
    • Remove the (2) two 9.2mm screws (circled in red) with a JIS #1 screwdriver.
    • Remove the back cover of the controller as seen in image (2) two.
  3. PowerA Fusion Controller For Xbox One Headphone Jack Replacement: passo 3, imagem 1 %32 PowerA Fusion Controller For Xbox One Headphone Jack Replacement: passo 3, imagem 2 %32
    • Desolder the soldered joints that are connecting the headphone jack to the motherboard (Circled in red).
    • This guide will show you how to solder and desolder connections.
    • Remove the headphone jack and put it aside.
Conclusão
Andrea
Membro desde: 09/26/17
647 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S14-G4, Boczar Fall 2017 Membro de USF Tampa, Team S14-G4, Boczar Fall 2017
USFT-BOCZAR-F17S14G4
4 Membros
Autoria de 5 guias
2 comentários
Has this been proven to work? Thanks!
Luis Lujan - Responder
real help full its like having a broken down car and a video online saying “open bonnet and fix car” no mention of where you can get those parts ie the most important bit the parts ie the female jack port !!!! other than not for sale !! blinding
James Price - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 41
Ao todo: 7,538
