Ir para o conteúdo principal
PowerA Enhanced Wireless Controller Motherboard Replacement
O que você precisa
  1. PowerA Enhanced Wireless Controller Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 PowerA Enhanced Wireless Controller Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 PowerA Enhanced Wireless Controller Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller Motherboard Replacement: passo 2, imagem 1 %32
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller Motherboard Replacement: passo 3, imagem 1 %32 PowerA Enhanced Wireless Controller Motherboard Replacement: passo 3, imagem 2 %32
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller Motherboard Replacement: passo 4, imagem 1 %32 PowerA Enhanced Wireless Controller Motherboard Replacement: passo 4, imagem 2 %32 PowerA Enhanced Wireless Controller Motherboard Replacement: passo 4, imagem 3 %32
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
Conclusão
Equipe
USF Tampa, Team S1-G5, Leahy Fall 2019 Membro de USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Membros
Autoria de 11 guias
1Comentário do guia
Je cherche un couvercle de batterie pour ma manette switch
Auriez-vous un site où il est possible de s’en procurer un ?
Merci
josselin cornet - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 50
Ao todo: 4,162
