Ir para o conteúdo principal
PowerA Enhanced Wireless Controller Action Buttons Replacement
O que você precisa
  1. PowerA Enhanced Wireless Controller Action Buttons Replacement, Motherboard: passo 1, imagem 1 %32 PowerA Enhanced Wireless Controller Action Buttons Replacement, Motherboard: passo 1, imagem 2 %32 PowerA Enhanced Wireless Controller Action Buttons Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
    Pergunte ao FixBot
    Comentar
  2. PowerA Enhanced Wireless Controller Action Buttons Replacement: passo 2, imagem 1 %32
    • Remove all eight screws using the J0 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. PowerA Enhanced Wireless Controller Action Buttons Replacement: passo 3, imagem 1 %32 PowerA Enhanced Wireless Controller Action Buttons Replacement: passo 3, imagem 2 %32
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
    Pergunte ao FixBot
    Comentar
  4. PowerA Enhanced Wireless Controller Action Buttons Replacement: passo 4, imagem 1 %32 PowerA Enhanced Wireless Controller Action Buttons Replacement: passo 4, imagem 2 %32 PowerA Enhanced Wireless Controller Action Buttons Replacement: passo 4, imagem 3 %32
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
    Pergunte ao FixBot
    Comentar
  5. PowerA Enhanced Wireless Controller Action Buttons Replacement, Action Buttons: passo 5, imagem 1 %32 PowerA Enhanced Wireless Controller Action Buttons Replacement, Action Buttons: passo 5, imagem 2 %32 PowerA Enhanced Wireless Controller Action Buttons Replacement, Action Buttons: passo 5, imagem 3 %32
    • Use the iFixit opening tool to lift the action button out from its place.
    • Pull the button out with your fingers.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team S1-G5, Leahy Fall 2019 Membro de USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Membros
Autoria de 11 guias
3Comentários do guia
Where do you buy the buttons ?? I haven’t been able to find them
Captain Chris Sherwood - Responder Compartilhar
Where can I buy the buttons?
Justinas Maraulis - Responder Compartilhar
For me, it's not the buttons, but the silicone pads for ABXY that have worn out. I've looked everywhere, but to no avail.
Radiohead - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 81
Ao todo: 5,501
