Ir para o conteúdo principal
Power Mac G5 Graphics Card Replacement
O que você precisa
  1. Power Mac G5 Graphics Card Replacement, Side Panel: passo 1, imagem 1 %32
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
    Pergunte ao FixBot
    Comentar
  2. Power Mac G5 Graphics Card Replacement: passo 2, imagem 1 %32
    • Remove all the cables, including the power cables before opening the unit.
    Pergunte ao FixBot
    Comentar
  3. Power Mac G5 Graphics Card Replacement: passo 3, imagem 1 %32 Power Mac G5 Graphics Card Replacement: passo 3, imagem 2 %32
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
    Pergunte ao FixBot
    Comentar
  4. Power Mac G5 Graphics Card Replacement: passo 4, imagem 1 %32 Power Mac G5 Graphics Card Replacement: passo 4, imagem 2 %32 Power Mac G5 Graphics Card Replacement: passo 4, imagem 3 %32
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
    Pergunte ao FixBot
    Comentar
  5. Power Mac G5 Graphics Card Replacement, Graphics Card: passo 5, imagem 1 %32
    • Locate the graphics card in the desktop.
    Pergunte ao FixBot
    Comentar
  6. Power Mac G5 Graphics Card Replacement: passo 6, imagem 1 %32 Power Mac G5 Graphics Card Replacement: passo 6, imagem 2 %32
    • Using a Phillips # 1 screw driver, unscrew the screw right next to the graphics card.
    Pergunte ao FixBot
    Comentar
  7. Power Mac G5 Graphics Card Replacement: passo 7, imagem 1 %32
    • Last thing to do is to gently shake the card out of it's slot by pulling it straight out. (If the card does not come out easily, don't force it. You need to release a latch on the logic board behind the AGP connector while pulling out the video card.)
    Pergunte ao FixBot
    Comentar
Conclusão
39 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 5-8, Forte Winter 2010 Membro de Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Membros
Autoria de 30 guias
5Comentários do guia
hello, i’m wondering what’s the maxi ram of graphic card can be accepted by g5? we know it can do 128m 256m in standard, but what if we install a 512m or even 1go ram graphic card, it there anyone who has tried please? thank you!
qian daniel - Responder Compartilhar
Hi Salvador,
Many thanks for the guide. I already knew all the steps until the ‘secret’ release mechanism, which is why I came to this page.
So, it would be really handy for future viewers if you included a picture of the position and design of the release latch. It would have saved me from fumbling around for 15 minutes pressing an unrelated button, which is situated just behind the release latch.
Anthony Lythgoe - Responder Compartilhar
I agree. The most important step for this to be helpful, the release mechanism, is not shown at all.
Anton Uhl - Responder Compartilhar
I agree too, maybe we could add a picture?
Hamish McIntyre-Bhatty - Responder Compartilhar
What are some compatible graphics cards to replace the one that's in the Mac by default? I tried taking it out and giving it time to rest. Then plugged it back in and it still doesn't work when I use a monitor on it. Any suggestions?
Yahia Milton - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 90
Ao todo: 44,946
