Ir para o conteúdo principal
Power Mac G5 Front Fan Assembly Replacement
  1. Power Mac G5 Front Fan Assembly Replacement, Side Panel: passo 1, imagem 1 %32
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
    Pergunte ao FixBot
  2. Power Mac G5 Front Fan Assembly Replacement: passo 2, imagem 1 %32
    • Remove all the cables, including the power cables before opening the unit.
    Pergunte ao FixBot
  3. Power Mac G5 Front Fan Assembly Replacement: passo 3, imagem 1 %32 Power Mac G5 Front Fan Assembly Replacement: passo 3, imagem 2 %32
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
    Pergunte ao FixBot
  4. Power Mac G5 Front Fan Assembly Replacement: passo 4, imagem 1 %32 Power Mac G5 Front Fan Assembly Replacement: passo 4, imagem 2 %32 Power Mac G5 Front Fan Assembly Replacement: passo 4, imagem 3 %32
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
    Pergunte ao FixBot
  5. Power Mac G5 Front Fan Assembly Replacement, Front Fan Assembly: passo 5, imagem 1 %32
    • Locate the front fan assembly.
    Pergunte ao FixBot
  6. Power Mac G5 Front Fan Assembly Replacement: passo 6, imagem 1 %32
    • Pull the fan assembly out; it should slide out easily.
    Pergunte ao FixBot
Conclusão
27 outras pessoas executaram este guia.
Adam
Membro desde: 01/22/10
873 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 5-8, Forte Winter 2010 Membro de Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Membros
Autoria de 30 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 100
Ao todo: 19,736
