Ir para o conteúdo principal
Porter-Cable PCE211 Motor Replacement
O que você precisa
    1. Porter-Cable PCE211 Motor Replacement, Gearcase: passo 1, imagem 1 %32 Porter-Cable PCE211 Motor Replacement, Gearcase: passo 1, imagem 2 %32
      • Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
      Pergunte ao FixBot
      Comentar
    2. Porter-Cable PCE211 Motor Replacement: passo 2, imagem 1 %32 Porter-Cable PCE211 Motor Replacement: passo 2, imagem 2 %32 Porter-Cable PCE211 Motor Replacement: passo 2, imagem 3 %32
      • Grip the body of the impact wrench with one hand and the gearcase in the other and firmly pull to remove it.
      • Be careful about any loose parts when removing the head.
      Pergunte ao FixBot
      Comentar
    1. Porter-Cable PCE211 Motor Replacement, Anvil: passo 3, imagem 1 %32 Porter-Cable PCE211 Motor Replacement, Anvil: passo 3, imagem 2 %32 Porter-Cable PCE211 Motor Replacement, Anvil: passo 3, imagem 3 %32
      • Firmly pull the to remove drill bit holder also known as the anvil.
      • Before replacing the anvil, lubricate the base for the best performance.
      Pergunte ao FixBot
      Comentar
    1. Porter-Cable PCE211 Motor Replacement, Motor: passo 4, imagem 1 %32 Porter-Cable PCE211 Motor Replacement, Motor: passo 4, imagem 2 %32 Porter-Cable PCE211 Motor Replacement, Motor: passo 4, imagem 3 %32
      • This section tends to get messy so it would be best to have a paper towel or microfiber towel handy.
      • Pull the motor out with your hands.
      Pergunte ao FixBot
      Comentar
    2. Porter-Cable PCE211 Motor Replacement: passo 5, imagem 1 %32 Porter-Cable PCE211 Motor Replacement: passo 5, imagem 2 %32 Porter-Cable PCE211 Motor Replacement: passo 5, imagem 3 %32
      • Wipe out the old grease with a towel. Use the appropriate motor grease for electric tools to lubricate the top area, base of the motor, and the space the motor sits.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Layla Berry
Membro desde: 09/19/22
678 Reputação
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 471
