Introdução
If you need to replace the grip of your Porter-Cable PCE211 impact wrench, follow this guide. You'll need to remove the grip to access the switch as well.
Be sure to turn off the device and unplug from the power source prior to beginning this repair.
O que você precisa
Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
Using the Phillips #2 screwdriver, remove the three 8 mm screws from the grip of the impact wrench.
Uma outra pessoa concluiu este guia.
